GPS Shield User guide (step by step)
All things pertaining to GSM/GPRS/Xbee/Zigbee/GPS
Moderators: vaico, sunzhanshan
Postby vaico » 2011-10-03 19:39
GPS shield is designed for arduino board.The GPS module and SD module included on the board, you can chose to use your own 3.3v or from arduino board. The board also can work without the arduino,you can use the PC to receive the data from the board.
Picture1 The up side of the board Picture 2 The bottom side of the board
Picture 3 GPS shield connection
P7---arduino ISP
P3---GPS_TX select
P9---3.3V POWER SUPPLY select
P2---GPS_RX
Picture 4 The LEDs & some other pins
GPS has 2 contral pins of power,one is GPS_PWR,the other is GPS_PPS.
Picture 5 GPS part
The SD module is connected to arduino through SPI, you can connect the signal lines with the 0 Ω Res or wires.
TEST :
Softare Platform : arduino
Hardware Platform : GPS shield & arduino 328
Test Result : Get the data from the UART:
$GPGGA,235947.034,,,,,0,00,,,M,0.0,M,,0000*5F
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPRMC,235947.034,V,,,,,,,281006,,,N*49
$GPVTG,,T,,M,,N,,K$GPGGA,235948.043,,,,,0,00,0P,PV,T
$GPGGA,235949.034,,,,,0,00,,,M,0.0,M,,0000*51
Picture 6 SD card Messages
shopping :
http://www.soliddepot.com/index.php?mai ... ucts_id=25
vaico
Bloggister.com
Postby dsami12 » 2012-02-09 10:36
Welcome to Bloggister.com
With Bloggister - Do Blog Become Ster users can communicate using quick status updates of 160 characters or less. This free flowing dialogue lets you send messages, pictures and video to anyone! It`s also easy to find and connect with other people for private threads and to keep track of their updates. All this and more in a simple interface.
http://bloggister.com
dsami12
Return to GSM/GPRS/Xbee/Zigbee/GPS
Who is online
Users browsing this forum: No registered users and 1 guest
cron
